And here I always thought I had a sticky fuel pressure relay. I'll have to pay attention to if mine lingers longer cold than warm to confirm. I can also watch the oil pressure gauge too I imagine.
Not all GM vehicles have this feature... do we know all which ones do...?
I know the 88-95 TBI trucks had it as well as the 96-98 Vortec trucks ( pre-LS). In 8 lug fashion, the early engines lived until 2000. GMT400 platform stuff. I haven't gotten that deep into GenIII and newer. When you turn the key to start, it bypasses the oil pressure switch. Once it's running though you need oil pressure to stay running.
This is a different configuration than what jderekt posted above...
his 2 redundant paths implies an OR function (EOPS in parallel with FP relay),
whereas your configuration implies an AND function (EOPS in series with FP relay)...
unless the ECM is involved (when it sees EOP fall down it shuts down engine)... is this how it works...?
from what I see on LS1tech, this would have saved many engines from the notorious pinched o-ring problem.
It doesn't actually bypass, it is a parallel scenario, but that oil sensor electrical path is closed when you first hit the key. There must also be a time delay in there too.
From what I have read, that EOPS circuit can kill a motor if oil pressure is lost or if the switch fails. I actually found this completely by accident
while reading a forum thread. So it seems at least with my rig, this circuit is the fuel pump control circuit once oil pressure is detected.
A quick update on this.
I recently installed the complete engine/trans harness from an 02 pickup into this rig. The old harness had gremlins I just couldn't seem to track down so I gave in and did a swap.
Well the gremlins are gone, and the fuel pump operates as it should now. So that proved up on the finding of how the 98 pump circuit was controlled. :grin:
Now on to getting the Auto VE tune completed, with some help from some of you experts.
Hey, that is cool, shows attention to detail by the GM engineers
