There is something wrong with the values @ 85kPa, that is insanely lean.
If the engine didn't miss or hesitate there, you may need a new WBO2 sensor.
http://forum.efilive.com/attachment....8&d=1251509350
In the tunetool go Edit->Properties and make sure you are NOT using Lambda fueling units.
So if you don't use Lambda there are two other options EQ and AFR. Which do you use?
How dumb and I. I hooked up the wideband in place of an 02 sensor. I just did it and didnt even think about how the tune would turn out. I was too excited to get the car tuned.
Anyway I have both 02 hooked up and put the wideband in the rear.
The car has a perfect tune now.
I had it dynoed, 446 RWHP 396 FT LBS TQ. Not bad for a stock bottom 346 with a ton of mods.
