Here is drivers side
Cylinders 1 & 3
Cylinders 5 & 7
Is it logging a misfire code? Fast flash on the dash?
Yes i did get a fast flashing CEL. It is my understanding that, that isnt good. Drove the truck over to the neighbors house (had to get my fix) just before i came to work and she set the CEL. I'll get codes in the morning.
Here are the codes, looks bad to me
I did check vin it is correct, is there a discrepancy between the 411 and the 1MB ECU pinouts, (can't remember the number)?
Made a short run, the tun is not set up for anything yet just a monitor run. Here ate the current DTC's
here is a short scan, I'm not ready to switch back to the 411 just yet. l0l
ok, I'll take a look.
