I'm logging on to a E40 and I have very limited PID's showing available other than a list of external PID's. I can read the cal as normal and have no connection issues to the ECU that I know of. Any ideas?
Every new vehicle you connect to, you should repoll for supported PIDs. Info -> Validate PIDs. Also make sure you select E40 when you connect to the controller.
Good deal :cheers:
