I'm using this pcm as a standalone....Can someone explain what this does? If I enable it, does that mean the electric fans will turn OFF & ON at the temps I choose? If it's disabled, does that mean it has a mechanical fan?
Anyone?
Is anyone even flashing these pcm's?...:help2::confused:
It is used to disable the fan clutch in the P10 PCMs (tested it works on my 02 TB P10), but thinking about it most (if not all?) P11s have efans anyway as they are transverse mounted, right?
So: Disabled = fan clutch
Enabled = electric fans
But if you're not getting lights and its disabled and you have efans already, who knows?
The stock tune had it disabled and fans wouldn't kick on at all, or they would kick on but at the wrong temperature and they wouldn't shut off at all...
So I enabled the electric fan parameter & did a full flash and fans are working perfectly...:D
A buddy of mine told me they can put the P11 into Open-Loop and tune for Big turbo's too...
Might have to invest...:D
I dont wanna drop $400 on their "stuff", EFILive's hardware is a generation ahead and we have more than just BBL functions. Id ask on their forum for some screenshots of their parameters to see if they actually can do what you want. Maybe someone close to you has a cable and will let you take a look and play with it?
Yeah, I didn't think of asking him to let me play with it first...hehehe
