Not sure whats happening but its not there
Do you have the LS1B_A highlighted (Not just checked) on the left side?
I think nevinsb has it.
Those pids in the right are all E38/E40/E67 pids, and the EQSPK_M pid you have loaded is a E38 only pid.
As nevinsb said, DYNAIRTMP_M is a LS1B only pid, and then it is defined for only some LS1B OS's...
you pic shows the E38 pidlist highlighted in the blue section in the upper left.
OK now Im getting somewhere. the only other one that I want is oil pressure but its not in the list (sensor volts is) thanks by the way
There isn't a direct oil pressure pid in LS1.
You can olny log EOPS, pressure is calcualted pid form voltage and can be displayed in v7 via CALC.OILP_LS1
Thanks thats what I thought. I have selected the pids that i want and programed them into V2 but when I go to read from v2 the pid selection is changed is that correct?
Is there a reason that you need to highlight the selected pid as well as have the box ticked ?
You don't need to checkmark the box...
you make sure the pid appears in the green section while one particular pid list is highlighted in the blue section...
when you have all the pids you want, and the bar graph shows no red at the bottom of the green section, then click Save, and then Program All (accesses via the downarrow next to Program).
Which pids are being changed...?
I think I see where I have been getting confused...when you read V2 you still need to highlight the pid list you need to view, I thought it would automatically open the one I had just saved
