What is the best way to increase throttle response with tuning? Tired of sluggish take off. 2014 2500 auto had emissions intact
Sent from my iPhone using Tapatalk
Granted I'm new to this but if you're talking pedal response in general then pedal to torque curves. You can add more columns and make more aggressive. I did just the opposite with my manual tune. I changed columns to 0, 50, 90, 100% and added all of the torque increase at the 100% column to make my pedal response feel like factory down low through 90%.
If you're looking for better response when you floor it period, then you're talking about spool time: then smaller turbo OR more fuel which taken to the limit results in black smoke which can be compensated for with nitrous.
I will try that and see
