October 2020, Release Candidate 4
ATTENTION - Release Candidate Software
This software contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
The current public release is available here.
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.056 (Oct 22 2020). Boot block will be updated to V3.00.005.
- FlashScan/AutoCal V2 Firmware: V2.07.167 (Oct 22, 2020).
Download here:
Known Issues for RC4:Issue #1:
Error $0106 when copying files from V2 devices to the PC via EFILive Explorer.
Workaround:
None - will be fixed in RC5 - planned for release in the next 24 hours. For urgent cases, uninstall RC4 and re-install RC3.
Issue #2:
AD voltages are not being recorded from V2 devices during pass-thru logging.
Workaround:
Feedback:
Regards,
The EFILive Team
