Charged my units to GRAMS but the MAF table is all out of whack. Compared to the data coming out of the Log.
Attachment 20797
Attachment 20798
Attachment 20797
Attachment 20798
selben is a BEN factor. ben factors are pastewith labels-> multiplied. not pasted with labels(over written).
calc.VET produces a factor(multiplier) for the MAF response and calcs a new VE.
I would expect numbers close to 1 for the selben.
My numbers are all 1.x not exceeding 1.25 But there were adjustmetns everywhere..
Does that VE table look odd to you? Would you think some of the values erroneous?
Attachment 20799
Thats after a paste from log.
Thanks everyone for the help in getting me this far.
1-3 g*Kelvin/kPa is about right.
looks ok. Did you filter correctly? did you hide cells with less than 30-50 hits?
Manually flatten out the big spike and the smaller spike, then manually bring the untouched part of the VE table up to blend with the touch part.
Looks like your VE table wants to be increased by adding about 0.2-0.3 almost everywhere... if manually blending is too hard, then just add 0.2 everywhere (to the untouched VE table)... and then go capture another log to see what it does.
Thats done it its dialed in very well at this point... Almost need to make myself a guide on everything to check when getting this started for the first time...
Thanks so much for all of them help...
Now its time to modify the spark tables... lol any guides for that...
After all of my endevors with that Transmission I had a few years back im pretty good with tranny tuning at this point.
The CALC VET is so much better than the old AUTO VE. So glad things have changed in a positive way.
Spark is easy to start with, just do global bumps until you get KR. Even then, you can just back off where you do get KR and make another global bump or 2. From there, I work in small RPM ranges and try to get a good number of hits in all the load cells. In my experience, the biggest gains on the 5.7 are made by bringing in total timing much sooner. The truck will hold OD much better and move about with a lot less pedal.
Teach me....
Bump Low and high Octane?
Here's the tune with the VE and MAF adapted as well as injectors for the marine intake...
Attachment 20802
setup a map to log the same axis data as the spark tables- RPM on the rows and GM.DYNCYLAIR_DMA on the columns. The data of the map is KR.
Add 2 degrees of timing at a time globally until you get KR. Then back off 2degrees in the areas of KR. Keep the map very smooth. I always manually smooth on a VE, but use the built in functions to smooth on the timing. Smooth keeps away KR. Always assess the values as sane or not before you flash in tune.
Keep in mind most of your driving is in the .36-.72 gram/cylinder range so focus there. You want your map to approximate an old school distributor. Make sure the base idle timing is set well- and matches in ALL timing maps.
Also make sure you understand all the limiters, adders, subtractors, and multipliers to final timing. Set B5915 to 0 throughout.
