Just wondering if there is any plans to support the CM2150 controller. I believe this would cover 2008-2010 HD cummins/off road.
Thanks!
Thanks!
Yes, it would have been supported in the initial release but the checksum methods Cummins used are inconsistent between the numerous reads we have from this ECM. So we decided to hold it off until we can come up with a way to process them all accurately depending on the method each ECM OS uses.
Awesome news.
I've been on the brink of rewiring to use a different ECM, but it looks like with a little patience the CM2150 will be OK.
Thank you.
Any news on this?
CM2150 will not be supported on the first release, maybe early next year instead. We did enable reading for them so we could get some files but that is it.
The problem is there is three CM2150 versions, CM2150C, CM2150D and CM2150E. The 'E' is very different to the other two, unfortunately by the time we got to the point of making the software stable and not adding in anything else the CM2150's weren't ready to be added.
Thanks, the reading and flashing was ok. As I said the issue was the differences in file structures and checksums between the CM2150C/D and the CM2150E.
In to follow... first truck i get has to be a 2150!!! read was sent to support!
Thanks Joe, apologies for the current unsupported status though.
Any update on the 2150's? I've also got a couple of them that are ready to be done.
Thanks for the help!
CM2150 hasn't progrressed. At this stage we are waiting on a larger number of reads to be submitted so that we can cover a wider variety of file structures in a single development task. We don't want to be reworking a soultion based on additional file structures being submitted post-release.
Cheers
Cindy
If I had funds for a HD v2 I'd have for sure another read for you if not 2 reads within a few weeks.
Would some converted Bin work for you? I could get you a lot of them if that's all you'd want.
Thanks for the offer Dom but we would prefer actual reads. As it stands we have a pretty good collection to make a decision now.
any new updates?
Should have some solid news with a possible release mid this month.
Almost 2 months later. Any update on this?
It's done and built into the software. The next release has a number of significant changes that require thorough testing prior to release. Once that testing wraps up CM2150 will be released.
Cheers
Cindy
Awesome! Thank you
Support was released on Friday
