How do I make a BEN Factor for this and create a PID? Thanks
Attachment 23123Attachment 23122Attachment 23123Attachment 23122I checked a few posts before, made my PID list and tried to make a Calc pids file for the BEN for the 0334, Is this Correct?
i made it using the calc_pids.txt, i dont recognize the interface in your screenshots. im assuming its v8.
the 23.49 in 017 is because my tune is scaled.
no promises that anything here is correct, its just what i did and it seems to be working but i havent tested extensively yet.
*CLC-00-015
AFR 10.00 18.50 .2 "({EXT.AD1}*2.375)+7.3125"
*CLC-00-016
factor 10.00 18.50 .2 "14.63/{CALC.AEM_AFR_VETTE}"
*CLC-00-017
factor .7 1.3 .2 "23.49/{E38.AFRATIO_DMA}"
*CLC-00-018
factor .7 1.3 .2 "{CALC.EQ_VETTE}*({CALC.AEM_AFR_VETTE}/14.63)"
CALC.AEM_AFR_VETTE F001 CLC-00-015 AFR Tuning "Wide Band AFR 1 - VETTE"
CALC.WB_EQ_VETTE F001 CLC-00-016 factor Tuning "eq from wb - vette"
CALC.EQ_VETTE F001 CLC-00-017 factor Tuning "EQ ratio scaled - vette"
CALC.BEN_VETTE F001 CLC-00-018 factor Tuning "BEN from wb - vette"
Are you using V7 scantool or V8 scantool...?
Are you using two widebands (i.e a 0333 and a 0334) or just one...?
joecar connecting via V8 Scan & Tune. one wide band 0334 only. Via CAN BUS
i cant seem to use it in V7 or im not sure how to CAN wise
You have to log with V8.
