Implication is that injector # is different than cylinder #.
I know this is an old thread but I have to be certain of this and the injector number being different is throwing me off. Which letter in b1520, the individual injector correction table, would I alter to affect cylinder 4 for example, E? I asked the same question of Paul of Efilive and he said that the leters follow the firing order, so cylinder 4 would be G. I have to get this right and am thoroughly confused.
1A, 2D, 3H, 4G, 5F, 6E, 7C, 8B or in firing order..... A1, B8, C7, D2, E6, F5, G4, H3. Although, I changed table B1520 drastically (small increments at 1st) and couldn't see a difference between my dual AFR sensor readings. I changed Bank 2 (cylinders B D E G in tune) from 1.0 to 2.0 with no obvious change in datalogs.
Where you able to balance the banks out by modding Table {B1520} ?
That's a shame, its would be useful for LSA's that run slightly leaner on the rear 2 cyls.Quote:
I didn't see any changes by modding the table. Wondered if I was missing something.....
for B1520 to be enabled there is a separate enable/disable bit that enables it. Not currently mapped.
I was reading on the hpt forum that some people who had tried it on the e38's were getting like a cut out around 4k rpm when they used it.
something to do with the cpu maxing out, e67 apparently doesn't have that problem.
