July 2016, Public Release
Please download and install both the V7.5 and V8 software packages.
Release Notes:
Version Numbers:
After installation, you should have the following software, boot block and firmware versions installed:
EFILive V7 software: V7.5.7 Build 309 To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 303 To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.102 (July 08, 2016) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
Known Issues
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
Issue 2:
When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
Workaround:
EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
Quote:
Originally Posted by
Snipesy
Wow I didn't know v8 pass through logging was a thing now. What have I been doing with my life? Well done!
It was originally added to April beta software, and has had a number of enhancements since.
Cheers
Cindy
Sent from my iPad using Tapatalk
