Thanks.
Thanks.
Log shows it idling at 73 kPa MAP...
so, also, check any table that uses MAP as a threshold, you now may need to modify these tables (e.g. C3003 and C3004, like In-Tech said above).
And C3905.
Hi Joe,
I don't see C3003, C3004 or C3905 in his tune. Am I doing something wrong? Just trying to follow along. :ermm:
I had a bit of success today ,I did the mods that I was told to do . No p0106 code . Now I still have the problem of the commanded AFR being supper rich. It`s killing the Dog when he walks passed ,if I had a dog. I`m not running a MAFF and I have set up SD. Would some be able to have a look ,I just cant seem to have and success.
Attachment 23218
Attachment 23219
{B1219} Low Volatility Fuel Detect ) was the cause of the over fuelling at idle.
Thanks for posting back. I didn't know that was even there.
