2006 Allison 6 speed shift timing changes
Ok Guys i am pretty new to efi live,just starting to play with settings a little.I would like to raise my shift points up a bit.I dont like how early it shifts into 4th,5th,and 6th.I messed with the upshift tables at part throtle but really not sure how far to go.I like the points it shifts at in tow mode just not the firmness when not towing a trailer.I need to have a copy of somebodys tables for part throtle upshift timing,downshift timing and also the torque converter apply and release tables that has done this with some good results.Im not sure what all has to be adjusted with this change and dont want to screw this thing up!My dads 04 5speed ally shifts higher and has alot more hold back when you let off the throtle in lower gears which i like.Any help on this would be great. Thanks Chris
