Known issues with Jun 21, 2014 release of the EFILive software and firmware.
Currently known issues and possible workarounds for the June 21, 2014 release of the EFILive V7.5, V8 software and the V2.07.62 FlashScan and AutoCal firmware.
The next update is due for release on or before July 5, 2014. When the next update is released, customers running the June 21 version will be able to update via the "Check for Updates" option.
Issue 1:
Some LML (E86) calibrations do not display correctly.
Workaround:
None, fixed in next update.
Issue 2:
*.coz files cannot be added to the BBx Quick Setup.
Workaround:
Issue 3:
E69 Black Box Logging does not start, all PIDs are incorrectly detected as unsupported.
Workaround:
Use E55 settings. Fixed in next update.
Issue 4:
KNKCYL1..KNKCYL6 PIDs are not available in Black Box Logging.
Workaround:
Issue 5:
Loading a BBX quick setup file can cause an "Access Violation" error.
Workaround:
Delete all existing BBX Scan and Tune items before loading a quick setup file, fixed in next update.
Issue 6:
Changing any DTC from Inactive to Active in LML tune files will cause a "Range Error".
Workaround:
Issue 7:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 8:
Adding files to the BBX quick setup list and then programming that quick setup list into AutoCal without first saving the quick setup *.bbx file will cause empty tune files to be copied to the AutoCal device.
Workaround:
Save the quick setup file using the "Save Quick Setup" drop down option on the [Save] button at the bottom of the BBX window before programming the quick setup into AutoCal. Fixed in next update.
Issue 9:
Calibration defintions for E38 OS 12618277 are not defined correctly. Do not edit/save tune files for that E38 operating system.
Workaround:
None. Fixed in next update.
