2 Attachment(s)
'02 Corvette A4 vs. '02 Camaro A4
Ever look at the comparison between the two? Aren't they supposed to have the same motor with the same internals? Why so different on the spark curve and fueling? It seems the Vettes have a lot more timing for mid-range rpm, but up top not so much. Plus, the injector flow rates are .05 grams/second leaner and voltage adjustment is different too. Maybe to account for a variation in the electrical system? You figure same injectors, same offset, wouldn't you? Just thought it was a little odd...
