Originally Posted by Blacky
Have you performed the "Validate PIDs" option using FlashScan?
Basically the validate PIDs option sets up the FlashScan cable to query the PCM for a list of valid PIDs. When you reconnect FlashScan to your PC, and selec tthe [Uplaod] option, the list of valid PIDs is loaded into EFILive and then EFILive will know which PIDs are valid and which are not.
Another way to achieve the same result, is to copy the *.vpl and *.vml files from the PIDs folder on your laptop to your desktop. Those two files contain the validated PID list (*.vpl) and validated module list (*.vml) for the vehicle with the VIN that matches the filenames.
It is the *.vpl file that is updated when you perform the PID validation.
