Originally Posted by
LS1_Dragster
Air flow may be low because I have an edelbrock vic jr and Holley throttle body. Since these are not stock I had to work the program around them.
I have found with the other cars I've done with larger cams it loves a lot of timing around idle, it tames them a lot and "takes the cam out" so to speak. If I understand the CO3 correctly when I set A0000 To enable and A0001 to 100% it will only use the high octane timing map.
Commanded AFR is getting better as far as driving goes, I've only put on a few miles since the rebuild. I was just concerned as to why cold AFR is not achievable.
Lee
