I agree, probably just a fluke. I have since flashed it several times and a few others with no problems. Still get a little nervous when doing it at the track though.
This is true Chuck, in the name of full flash them, my bootloader code was wrong, it wiped the flash 100% then crashed.......doorstop.
We had a car over here in Australia recently refuse to be flashed, we got some before and after .tun files and it looks like the write simply missed a block of data. Seems very odd that it only happens on some cars every now and then. We are still looking in to it.
Ross, When writing to these do you remove the comms fuse in the front left hand kick panel at all?
Ok Thanks for that... I know that Holden recommend you pull the 10A fuse for the SDM so it reduces the chatter on the line before flashing.
T43 reflash problem solved:
http://forum.efilive.com/showthread....114#post110114
Great to hear, know its been bugging a few people!
:cheers:
