five years later and works like a charm.
tks
tks
Yes, the calc pid can be modified after the log was taken...
you edit the calc pid, restart the scantool, select the calc pid, and save the log (if you want to make the calc pid be selected each time you open the log).
Any time you open a log file, the calc pids will be as defined currently (i.e. if you edited any calc pids, then the current content of calc_pids.txt is the current definition of those calc pids).
Cool it worked !!!
Blacky thanks you make it so easy.......
I've been searching for hours and I figured it was time to ask my question. This is the closest thing I have come across so my question may be appropriate.
I have the MXT-L and I just got it hooked up through the AD1 connector. I am reading 0-5 volts when I log (mostly 2.5v). I do not have the correct serial cables so I am going through analog. Still learning more so than getting precision tune.
I need to convert this voltage to the correct value AFR or Lambda (whichever is more appropriate). This is the info I have from my instructions: 0V = 7.35 AFR and 5V = 22.39 AFR. What I came up with is AFR = 3*V + 7.35. Where do I put this formula so I can do the calc.vet that is in Shawn's tutorial?
I hope I did this right and am on the right track, I added this to my calc_pids.txt file. I do see it as a valid PID in my PID list now. Too late to test it though.
*CLC-00-222
V 0.0 5.00 .1 "{EXT.AD1}"
AFR 7.35 22.39 .2 "({EXT.AD1}*3)+7.5"
CALC.AFR_MTXl F222 CLC-00-222 "AFR,V" WO2-Analog "Wide Band AFR 1 - Wideband MTXl"
For the MTX use the LC-1 AFR pid (has the same V->AFR transfer function):
CALC.AFR_LC11
