See post #1 for the latest calc_pids.txt file.
gday all just trying just trying to set up my pids list and when it comes to the calculated maf pid all i seam to have is a calculated maf,not corrected.yet it is not supported by my pcm.im running os 01290005 osid v5.how will this affect doing calc.maft.
thanks
Do you see the pid CALC.MAFN...?
Does it have a red thru it...?
On the PIDs tab, click on the column titled "Parameter" (to sort the pids by this column), and scroll down until you see CALC.MAFN and CALC.MAFT...
if either of those have a red X, then do rightclick->More Info to see which other pids need to be selected.
thanks for the reply joecar
right click did the job i had to add
dynamic air temprature from the tuning system calc.dat
i had dynamic air temprature from the tune system gm.dyncylair_dma.
it seams to work now.time to log.
thanks again.
Ok cool :cheers:
I tried to use those PIDS but it does not allow me to do it as I think it is an old version of EFI live. Am I doing something wrong or does it need to be updated?
I have a V2, its a 2002 pontiac Trans am, and its the V7.5. Its when I download the PID text file and try and open it in the tuning tool, there are no PIDs present. Also, when I try and add the PIDs by myself some of the PIDs are not there to add.
Ok, please go easy on me as I'm new to this! When you say "disable maf", how do I disable it? Then I do not have a WBO2, so can I then still use this setup to tune? Thanks!
Did you copy the calc_pids.txt file ti the folder User Configuration...?
Did you name it calc_pids.txt...?
In the scantool, on the PIDs tab, click on the column heading of the right hand column to sort by tbat column, scroll down, look for those pids, do you see them...?
~ posted by phone ~
