I see you guys snuck in the new EFILive logo into the V7.5 splash screen...very sneaky! (Hope this or RC7 was the first time this happened, otherwise I obviously havent been paying attention!)
I tried tuning a 6.7 today that was a 08. I have the latest version downloaded (I think) Auto scan worked but it took 30 minutes to read the stock tune and im sure thats not right cause i read somewere that they sped that up a bunch. I couldn't license or tune the truck so im guessing something i did with software isn't right. Any help would be greatly appriciated thanks, Eric
Eric, we have been playing around a bit with the 6.7L read times, on first release it was just on 30 minutes, but it was stable. Since then we've sped things up with one release down to about 18 minutes, again there didn't seem to be any issues with stability. The current RC8 release should read one in about 11 minutes, but this is pushing the ECM to it's limits as far as how fast the Dodge read routines will allow us to get the file. I don't think there has been any reports of failures which is a good sign. Quite often what works on a test bench doesn't play as nice in the vehicle.
Anyway, the release this thread is for is indeed the latest, if this is what you are running then perhaps you didn't update the V2's firmware as well, that must be done as it has a necessary update for the faster read times.
It did need updated. it autp updated to this but i still don't think its the latest version and it won't let me type it in manually. The bootblock is 2.07.02 and the firmware is 2.07.12 Now on a different screen looking at the same stuff it says bootblock is 2.07.03 and firmware is 2.07.22? Im not computer stuipid but somethings kinda stump me lol. Thanks for being patient with me. Ok, I refreshed the first page i read the old version from. Now it is stating the new boot/firmware. As i stated above.
BootBlock needs to be DEC 12th or 13th, and Firmware Jan 6th. DO NOT AUTO UPDATE till further notice from EFILive!!! Note: when downloading this RC8, you will need to manually program BootBlock and Firmware files to FlashScan as well as Format Config file system and program all files for the controller you want to BBL or BBF. See previous posts in this thread for more info.
Where do I find the January bootblock? I've got the January firmware, but the bootblock is from Dec 12th. Didn't see it in my bootblock folder. Also, I'm not sure what you mean by. I see the format button under the config files tab - there is no info in there now. What files do I need to program in there?Quote:
Mike
You're right. My mistake. DECEMBER 12th.
And what I mean by Format Config Files is to Format Config in V8 and select CMB849 (for example if you want to flash with just the V2 without the laptop) and program all files slower.
