Thanks Paul and Joe I will post log ASAP
One last problem i have with E78
when i select an area in the log it should mark the same area in the high octane or low octane spark tables in tune tool but it does not
I tried to log E78.APCYL_DMA and GM.CYLAIR_DMA without luck
scantool/tunetool linking (if you enabled in the tunetool properties) only occurs if you logged the link pids mentioned on the axises of the table in the tunetool...
if the table axes don't mention the link pids you want, you can edit cal_link.txt (in the folder C:\Program Files\EFILive\V7.5\Configuration)
[ locate the table by it's id, and add the pids you want (separating with a comma , ) ]
( if you look in calc_link.txt you can see examples of multiple link pids on tables axes ).
For example:
in calc_link.txt you will find:
Code:
;High octane spark map
B5913.ROW=SAE.RPM
B5913.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYLAIR,CALC.CYLAIR
;Low octane spark map
B5914.ROW=SAE.RPM
B5914.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYLAIR,CALC.CYLAIR
you would edit those like this (don't forget the commas):
Code:
B5913.ROW=SAE.RPM
B5913.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYLAIR,CALC.CYLAIR,E78.APCYL_DMA,GM.CYLAIR_DMA
B5914.ROW=SAE.RPM
B5914.COL=GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYLAIR,CALC.CYLAIR,E78.APCYL_DMA,GM.CYLAIR_DMA
