Also, I'm just running the factory map sensor. Should I get a 3.3 bar map sensor?
If you're running boost then you will need a 2-bar or 3-bar sensor, and you will need to edit the MAP scaler parameter.
OK. I'll get the map sensor. Also, when I get it would you be able to help me on some adjustments. I'm still learning haha
