Thanks again. I was just testing the install on a different PC before I updated the one we typically tune with. That's why we ran into the new install issue. Cheers!
Is the auto update working now or not yet ?
Also is there any tables added to E78 since V7.5 build 235 ?
Still need support for my E78 Sonic...any idea when new OSs will be supported?
The auto update feature is only compatible with public releases.
The release notes list the changes in each software version and can be viewed here http://www.efilive.com/latest/cat/download-efilive
Cheers
Cindy
Anyone else loose PID descriptions for BBL with this update? I have bunch that just show PSI and temp with the actual descriptions gone like IAT, IAT2, Baro, Boost, ect. This is on the actual V2 while logging, I have not check by opening the files in the V7 scantool and this is on a LMM. I have not tested on any other vehicles yet.
Yup that's were it's at, maybe I will try formating everything and start over from scratch then reload again on the V2. I did get some file opening problems on the update during the install I dont remember if it was the V7 or V8 install but I did have to retry like 8+ different times for different files to complete the update.
No, don't do that...
do this: in V8 S&T when opening BBL, read the file Options.txt, and when making changes write to Options.txt... make sure you read/write Options.txt in the folder My Documents\EFILive\V8\Config.
