Yes, correct, no laptop...
to do this, you have to make sure the BBx config mentions your PCM ( V8 S&T -> BBx -> Tune ).
You will need an SD card.
I tried just using v2 with the same custom key message. I have a copy of the current tune but pulled with hpt. it won't allow me to post it here
Hi Matt,
go here and do what this says (it will guide you thru getting all the needed info): 7778-QEKN-0400
Paul needs this info:
Also see this: 8254-QOGC-9586Quote:
... supply the appropriate V8 *.blx trace file from a failed read attempt with the "Try Alt Keys" and "Assume Lock May Be Faulty" check boxes checked.
Hi Matt,
Enclose the HPT file into a zip file and see if you can post that.
here it is
I just switched to a different laptop but i'll try to get the info needed asap
I believe I just figured out my issue. I believe the os is a 1bar maf enhanced custom from hpt. if someone can verify that would be great. I've never used hpt but it looks like a custom os. if so is there anyway to flash a stock os back in?
Were you able to look at the posted file? If so is it a custom os?
Yep; it's 1 Bar MAF - Enhanced, converted from 12202088.Quote:
Originally Posted by outkast
