I have a 2004 lly and tried to get it tuned by a efi live guy he said it was lock so I then when to gm to have it reflashed to stock and they could not even do it they where getting error code 12 any one have any idea how to get unlock???
You need to find the key to unlock the ECM, without the key, your ECM cannot be reflashed. The original tuner may provide it for you, or you need to find someone with an unlocking service, like the one Jesse offers at wait4me performance.
The other option is a new ECM.
Cheers
Cindy
It had a edge programer in it before
Does it by chance have an aftermarket radio in it? I just went thriugh this with an 05 LLY where it said it was locked and all kinds of errors. Pulled the radio fuses and got a no response from anything on the bus. Pulled the radio out, unplugged the radio interface adapter, and the read and flash went through without a hickup with all fuses intact. In the past pulling the fuses has worked, but this time I had to physically remove the interface adapter to get the flash to go in. It had a superchips on it, and they had him go through and pull the fuses, and eventually said his tuner was bad and he needed to spend $200 for them to fix it. After pulling the radio adapter it worked just fine again, but he stil lwanted EFILIVE with a DSP5 from me.
Yeah have after market deck I'll have to try and pull that and take it to gm agine to see if it will flash
And what is the radio interface?
It is used to a allow the factory steering wheel controls to work. It seems anything that hooks into the bus wires can and will cause flashing issues in an lly.
Pull out the radio and follow the wires you should find a small box of sorts. Disconnect all the wires going to that box and try flashing again.
Thanks I'll give it a try but It would be lock because a tune us lock in it ?
Not lock the tune, but due to rogue databus messages confuse EFILive into thinking the ECM was locked due to timeout, message corruption, etc.
