Maybe its post count
I do need a link to your write up but not sure if its ok to share my email address on the forum
http://uploads.tapatalk-cdn.com/2016...1fd036f8b2.jpg
Ask an admin?
Sent from my Nexus 6 using Tapatalk
Hope you got it
I enabled email from other users,but have nothing on private messaging. Wont let me post my email either.
duramaxdiesels
Im having issues with scan in v8 july release (stable)... When trying to log pass-through the monitor function will not update params until the mouse moves over them, and it doesnt regularly update, only when the mouse passes by, but works fine recording... Also, not one of the boost parameters report when logging pass-through work, and i cant find any that work on bbx either. Is boost a param, or a math off of the MAP and BARO? There are so many different boost pids and i cant any of them to work... The math pid for actboost references BOOST_M and TCBP and subtracts BARO from it... That makes sense but the pid tcbp reports 0 constantly, and the pid BOOST_M isnt even on the list... How do i monitor actual boost? Also, when trying to view the math for the actboost param, it will open and show the math only once. Subsequent attempt result in error... See attachments
Please advise
tested on the beta. the TCBP shows 0 for me too.
I normally just log desired & sae.map. then i created my own calc pid to show the difference between actual & desired.
