Afr fluctuations with olsd
Hi all. I have been battling this issue for months now and still can not seem to figure it out. My issue is that the car starts and runs great and idles right around 15.0 but as it warms up eventually gets to about 12.8. I first thought it was something that i had messed up in my tune so I decided i would bite the bullet and buy a tune from a very well known reputable tuner. Well it still does it. I contacted the tuner i bought the tune from and he says that running in olsd that the car will only run off the main ve table so there has to be something else going on with the fuel system. Is he right about the ve table that nothing else will add or subtract when running in olsd? I can post logs if this is not the case and there are other factors that will effect idle afr. Car runs perfect otherwise.
Sent from my iPhone using Tapatalk
