I'm sorry, I didn't get the controller type. I can usually recover the E38s when they get munched or the E60s, but I dont
have much experience with those.
Chuck CoW
Chuck CoW
i get the above Access Violation whenever I look at Calculated PIDs in V8 Scan & Tune Tool. I can look at the first PID okay,but the second PID (even if it is the same as the first) causes the problem. I've tried it on both build 303 and 304 and the same problem exists in both. It also happens in either 'SCAN', 'CONFIG' and then 'Calculated PIDs' or 'BBX','Calculated PIDs' and Right Click the mouse on a PID and going to 'More Info', I tried it on an old build 294 and everything is okay.
