Anyone know what ecm would be in a 2007 F650? its a 5.9 motor customer wants to tune and delete his not sure if its a supported one or not. trucks not around for me to look at either
I believe it is a cm 850
that a supported ecm?
It's in the beta software now
who all is doing cummins hd tuning cant see a list of those doing it anywhere
A note, the just added (but older) Cummins ECM's such as the CM850 only perform read and flash functions, editing is not yet supported.
Reason for that is Cummins did some pretty major changes on these older ECM's that mean depending on the year it was made you can have totally different communications protocols even though it is the same ECM so we wanted to get that all sorted before attempting the editing side of things.
DieselMafialb, every ECM has the model printed on the label stuck to it, if your customer can maybe just take a look and confirm what it is (even get the ECM P/N and we can check by that too).
I think the 5.9L did use the CM850 (introduced in 2002) and the 6.7L of the same era used the CM2150 (introduced in 2007), I don't think the 5.9L used the CM2150 at any stage on the F series trucks.
P/n 4921776
s/n30010746
cm850
That ECM has only been recently added for just read and flash only, there is no editing yet sorry.
