Thanks Joe. Good to see you again.
Quote:
Originally Posted by
joecar
You meant V7.5 and not V7.4, right...?
Of course. And I actually proof read. :(
Quote:
There is no Update FlashScan V2 Firmware under Start->All Programs->EFIlive V7.5
Right. Some of the documentation floating around seems to be a bit dated.
Quote:
Firmware Programmer under Start->All Programs->EFIlive V7.5 is for updating old-style firmware, not new-style firmware.
Yep, I found that later.
Quote:
THIS IS IMPORTANT: which firmware version is currently in your V2...? if it's old-style, there may be a special sequence of steps to update it... let me know asap.
That is a problem, since the V2 is unresponsive.
Quote:
Which V7 and V8 software versions do you have installed...?
The November versions downloaded yesterday - 7.5.15 and 8.2.10
Quote:
Also, is your FSV2 currently in dead-poll mode (two amber led's flash alternately)...?
No. It sits with a blank screen but the backlight is on.
When I plug it in, all lights flash once, then a delay, then the blue light flashes once, then the yellow light next to it flashes twice. Then blank.
I'm wondering if the "no device found" message is due to the usb drivers getting messed up on the upgrade since I could talk to the V2 before I upgraded 7.5 and 8 but haven't had time to chase that yet.
