Its all off because the fuel is off. What was posted was to get it started and check for throttle body or tune issues. Do you have a wideband?
I have an Innovate LM-2 but is not connect to the v2. But yes the throttle body issue appears to be fixed. If it is capable (and I will check) to be hooked in line via serial port to the v-2 then I can hook it up but at the moment have not tried.
