1 Attachment(s)
How to set up RoadRunner with LC-2 Serial Widband
Hi I`m new to the forum and new to Efi tuning,are there anyone who has the opportunity to help setup/program V7.5 Scan and tune together with Roadrunner and LC-2 Serial Wideband.
The firs ting I going to try to tune is the B0101 and B5001
1. what pid`s to use in
LS1_Link
;Main VE Table
B0101.ROW=SAE.RPM
B0101.COL=SAE.MAP
B0101.RRR=CALC.?,
2. what Pid to use in the PID`s , I have made this one below
[ATTACH]22540
3. Have used the calc_pids.txt from Calc.VET: correcting MAF and calculating VE (in single log)
4. how to create and use the filter in the RoadRunner menu.
5.have tried to log but did not get the same values in RoadRunner B01001 that were in VET Maps ,
6.got no values in the RoadRunner box that shows Data for RTACS
The car I'm going to tune is a 72 firebird with 70mod 400 Pontiac Ram Air 3 with 4l80e which I've converted to be controlled by 0411 PCM, has been helped by Lextech to put together the progam.
BR Ponrov
