Ive downloaded the software for a nosey before I actually get my EFILive, and downloaed several of the files hosted on Holdencrazy's site.
They appear to be a different format though, and I cant load them into the software ??
They are all in the standard EFILive Tune Tool format. Which ones are you having a problem with?
Well, all of them really...
When I try to open any of them, they dont appear in any of the folders Ive saved them to, due to them being a different format.
but as I say, I am still using teh demo version of the software, unless that matters ?
Well that is very strange. I just downloaded one now to test, and as expected it works absolutely perfectly :).Quote:
Originally Posted by stevieturbo
Are you saying that you can't find the files you downloaded or that there are problems opening them?
The version of FlashScan should not matter as the file format has not changed since initial release. Generally a good idea to be running the latest build though in any case.
Don't know what to say to help really as all the files are valid and are hosted correctly.
Whats the file suffix? Should be either .bin or .tun to open ok.
Some .bin dont work, but old ls1edit and I think some hpt do.
You can try to go File Open instead of doubleclicking the file.
Thats what I have to do with .bin files.
Any chance your saving them to "My Documents\EFILive..." and then looking for them in "Program files\EFILive...."Quote:
or vice versa?
Ahhhhh, I had saved the files into Program files, rather than My Documents. I wasnt aware of the folder in My Documents.
Working now thanks...
Phew :Eyecrazy:. That was going to be some work for me if suddenly the hosting wan't working.Quote:
Pleased it is all good now :beer:.
:cheers:
I'm sure from a programming stand point it makes sense, but it is a source of confusion for many Newbies.
Quote:
Originally Posted by Trippin
You are haulin'
There's always plenty of room for any tunes available! Contact me.
looking for stock tune for a 2011 duramax 6.6 with egr and def delets with unlimited vin apreseat it.
Is holdencrazy.com out of commission?
This too?
www.tunefiledepot.com
so what happened with the tunes?
I have uploaded the files to here if you need them
https://www.dropbox.com/sh/4ydh5wltk...s4SRJ9NGa?dl=0
Awesome thank you, are you going to add gas trucks soon?
Thank you!
Cummins (2006-2016)missing '09 and Duramax (2001-2016)partial set - Stock Tunes
Looking for a stock 2009 Pontiac Slostice 2.4L tune to compare with my buggy tune. Cooling fans don't want to come on.
Meanwhile, a Hummer H3T I5 stock calibration to share.
Attachment 19906
Even though that's an older copy of the tune file depot tunes, thanks for hosting it in a drop box for everyone.
Here are some 4.8/manual trans RST truck factory GM tune's.
FWIW, I believe The factory 2006 LQ9 tune is not correct for a 2006 model year and likely will be in rep mode with the tach and pedal change.
Let me look at what I have on my other laptop and see what I can share.
I Found 2 of the 2006 LQ9 OS's from a 2WD SS. Early and Late.
Thanks for posting.
Here is another one I submitted on the old site that was lost.
2012 GMPP 6.2 LS3 file
Does anyone know where I can find the 8.1L express van tune for doing an 0411 conversion on a 1999 L29 454?
I haven't looked, but try here: Tunefiledepot-no-longer
no such luck on that one. Thanks though.
I'm a newbie will upload lots of stock files via mega
This thread is a little dead but I would like a stock 2007 Z06 tunefile if anyone has that laying around please.
Thanks,
Try here: https://www.dropbox.com/sh/4ydh5wltk...s4SRJ9NGa?dl=0
If not I have all of those files saved on PC, can upload when I get home.
Time for my next project: Anyone have a stock 2015 Cadillac ATS LFX V6 tune file?
newbie here!! 2011 lml stock tune??
Take a minute to read through this thread and you'll find your answer.
oops. thanks.
Search through the thread. I need a stock tune for 2014 Cadillac CTS Vsport, Twin Turbo
Anybody can help?
