Originally Posted by
WeathermanShawn
Hello:
A little disappointed that as a dedicated user of EFILive, I never received any response to the question of utilizing Strims to 'smooth' the VE table via Roadrunner RTAGS
A number of us are new users to RR, and any information that someone can share to maximize its phenomenal capabilities is always greatly appreciated.
However, I understand people are busy and my follow-up is to simply confirm that the method is still applicable.
While unable to utilize the VE Fixer through RTAGS , it can still be done manually (as the post indicated).
Utilizing SHRTF pids, just used the following calculation:
SHRTF1+SHRTF2/100+1.
After logging, and applying the 'standard' filters (TPS, DFCO,etc), and utilizing the EFILive MAP function, simply cut and pasted it to the VE Table.
Definitely 'smooths' out the VE Table, and after a few passes it has nearly zeroed them out.
Hopefully the RTAGS method for VE Fixer will reappear at some point.
If I missing something, please let me know.
Thank you very much.
..WeathermanShawn.
