so you have to have a roadrunner for this to work??
Yep. But I believe you can map your STFT's and copy paste and achieve a similar result.
So is a road runner necessary?
Quote from Page 1 , post #8 : T is for any controller you have strims set up on. not just ls1. also it dont have to be used with a roadrunner. You can use it just like your Ben filter for the ve tables with the paste and multiply feature.Quote:
Originally Posted by mikeyayell
So , no , don't need RR .
I had this working before I upgraded. Now I have the pid setup and selected but cannot setup a MAP as the Strim is not available as a dropdown menu option.
Any ideas?
Have you checked that all the cal_link files are upgraded?
Yes. I have gone over both files that were modified. I can't understand why it is an available pid but not available in the MAP menu.
What the hell, I'll check them again.
OK. When I look at teh pid descriptions, for Strim under units , it is blank. Any ideas? I have checked my entries in both text files numerous times. I am assuming the issue is in the sae_genereic.txt file but I cannot find it.
NE1?
Have you made the changes to BOTH cal_link files. There's one in My doc's as well as one in program files. The sae_generic file is in program files only. (all under user config).
All three txt files seems to be in place. Here is a copy of the pids. The strim pid shows up but with no entry for units. When I try to create a map, the strim is not available in the dropdown menu for data parameter.
