OBDII end?
http://www.obd2cables.com/products/o...les/?limit=all
You would need to crimp the RJ45 end for the V2.
I ended up buying a set of crimpers from Radioshack when the clip for the RJ45 plug broke.
They have been used at least 2 more times since. :hihi:
I do have a crimper Just need to get wiring order and hope they have the same amount and order of pin at the obd2 male end
Big thanks to you Mr.P! I just hope the I will be ordering from them has the correct pin on the OBD2 plug end
The OBDII end should be standard. :nixweiss:
Make sure to double check the wires for the corresponding pins.
The cable pins for FlashScan are shown here:
http://download.efilive.com/Tutorial...20Tutorial.pdf
tHANKS bLACKY
