Oh I see, the hot keys only work while you are in a menu.
The point is to power up FlashScan, then press Ctrl+F1 (or 2 or 3 or 4), then press the start logging button (the zero key). So you can start logging in 2 keystrokes.
No issues updating boot and installing new PC software. However Vista has issues with EFI Explorer and Hapi writing to the ini files they try to update stored under Program files\efilive. I had to give the folder write priviledges for the regular user group.
Using those two files, it all works as expected on my WinXP system here.
I put TEST-CAT.pid in the folder: \My Documents\EFILive\V7.5\PIDs
I put TEST-CAT.mls in the folder: \My Documents\EFILive\V7.5\MAPs
I started the Scan Tool, selected the PIDs tab page and opened the TEST-CAT.pid file.
The four maps specified in the TEST-CAT.mls file loaded into maps A thru D correctly.
There must be some configuration difference.
Exit from all EFILive software, then delete the reg key:
\\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Map
Then restart the Scan software and load the TEST-CAT.PID file.
Yes, well, more like switchable options, more details soon. Paul's new car has been a test rig, even causing embarrassment on the freeway when he forgot he'd switched it to valet mode.
Yes you could if you set up one of your tunes as a Valet mode. At this stage it will only switch your DSP tunes.
What OS is that Justin?, or all of them?
