not really unless some one wants to make you a script to do it.
Ok, so I have to pull up every table and set the new % and then save it all, right?
I just went and looked from b2210-b2215 and currently all %'s in columns 600-800 rpms and 0-20mm3's are at 80-90 something %. Is it really ok to go from that down to 10%, cause right after going up from 800 rpm it increases dramatically. I guess since I am so new to this it seems like a radical change...??
Dmaxhawk...thanks for the response man, I think I will try it myself as Im on two different computers right now and my zip drive is nowhere to be found!! haha. I also think I will try turning upp the timing as herculesdmax recommended and I may even try and disable the pilot injection at idle, do you think these are good ideas?
No problem. You still use Zip drives?? get yourself a jumpdrive:grin:
I tried turning the timing up and disabling the pilot injection and i didn't like the way it ran. But thats just me, you might find that you like it. I haven't messed with it since then. I might try it again to see what I come up with.
What did you not like about it? By the way it sounds, the two purposes for this is to give it a louder rumble and to reduce the amount of smell at idle? When herculesdmax gave all the tables to zero for disabling pilot injection, was he saying to zero the entire table from top to bottom? I can see how to do that, but have no idea which tables to go in and move timing up. Too late tonight, but I have shut of egr function and taken the hiss at idle away!! Iguess enough for tonight...let me know what you think..Jason
IIRC, it ran rough. This was with a cold motor back in February i think. So i need to try it again with a warm motor. He said the timing was to reduce smoke at idle. Yes, zero out the entire pilot injection table. The timing tables are B0908-B0910, increase timing by 4 degrees in the idle part of the table (0-600 rpm, 0-15mm3)
Thank you, I may just try this and see if I like it...thanks for your help...Im new to this forum and to EFIlive, glad to have made a friend!! Jason
