Alright.. i've read all the tutorials, manuals.. etc.. but I still need some hard info..
I have the LC1 with the dynotune gauge.. hooked up like that it works great.. from the WB to the gauge..
And, I AM NOT USING THE STOCK LOCATION.. I have a bung.
Now;
For flashscan I have selected the following PIDs.. BEN_LC11.. and I get this in the info box..
PID value cannot be determined because
the following error would occur:
Divide by zero.
I also have selected AD1 and AFR_LC11
Now, I have the brown wire (analog 2) going to pin E
Here is were I get really lost.. is there a way to see the read out on the gauge and also record thru Flashscan? I would like to know very specifically what wires to use (with color, please) especially the grounds, either way.. even if I can't run the gauge and the flashscan.
I have already tryed many ground combos but from what the instructions say..
I put the white and green wires to the pin D, and I fired up flashscan.. validated etc.. and nothing.. it reads the same whether it is plugged into the interface or not. Also, after i disconnected my gauge didn't work right because it wasn't grounded.
WHAT AM I DOING WRONG??
PLEASE PLEASE help, i've been struggling and I figure it is something simple that i'm overlooking but all I know is it will not show the AF that the gauge is, then I unhook the pins from the flashscan and it reads the same through the scantool.. so obviously its not getting through somehow.
Thanks,
Chris
