Try checking it then unchecking it.
What step are you on?
LC-1 WBO2
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
I made it through. I have the following installed...
Bootblock version 2.05.08
bootblock date apr 25 08
firmware version 2.06.06
firmware date dec 14 08
I could not get the dec 15 08 version to take?
Should I upgrade further???
Thanks for all the help guys.
LC-1 WBO2
Now with EE, under the config tab, copy the pmm files from
C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config
to the V2.
LC-1 WBO2
You can drag and drop them, or copy and paste them.
Hold ctrl to be able to select more than one.
You can install them all or the ones you want/need.
LOL I`m not sure if they are necessary for pass through, but they are for BBL.
LC-1 WBO2
You got the firmware/bootblock upgraded sucessfully, good job...
To configure V2, as mr.prick said, drag and drop from within EE...
Also, goto the Scan tab and the folder C:\Program Files\EFILive\V8\Scan and copy the .dtc files.Originally Posted by Upgrade document
More hints...
Using BB Logging:
Before you can log any data you must format the Data File system. The Data File system and the Config File system (that you formatted earlier) are kept in different areas of the flash memory. You can safely format one without affecting the other. You can only format the Config File system using a PC and the EFILive Explorer program. That prevents you from accidentally erasing the configuration files while "out on the road".
FlashScan supports two Data File systems: An internal flash memory chip which can hold about 2.7Mb of data and an external SD Card that can hold between 64Mb and 2Gb.
To format the internal Data File system, press Ctrl+Backspace, then use the left/right arrow keys to change the File sys: setting to Internal and press OK, then to format the Internal file system, select: F4 Options -> F2 File System -> F3 Format File Sys.
To format the SD Card File system, press Ctrl+Backspace, then use the left/right arrow keys to change the File sys: setting to SD Card and press OK, then to format the Internal file system, select: F4 Options -> F2 File System -> F3 Format File Sys.
You can also format the SD card using a PC card reader. Select the FAT32 (or just FAT) file system when formatting the SD Card via a PC. If you do that, you must create two folders on the SD Card:
\EFILive\V7\Scan (which will contain the BB logging files)
\EFILive\V7\Tune (which will contain the tuning files)
WARNING:
NEVER insert or remove the SD Card while Black Box Logging is in progress (or any other operation that writes data to the SD card), you will lose some or all of the data stored in the internal flash memory and/or data stored on the SD Card.
The blue LED on FlashScan’s keypad will illuminate whenever FlashScan is writing data to internal or external flash memory. Note: the blue LED will only illuminate when the LED Mode is set to “S” (Status).
1. Using FlashScan's keypad select F1 Select PIDs, then select the desired vehicle controller by using the up and down arrow keys, then Ok to select the desired controller.
You can also set up hotkeys to quickly select one of four preset PID lists.
2. Once you have selected a vehicle, FlashScan will return to the main menu.
Select: F2 Scan Tool -> F1 Data Logging.
Select F1 Record Data to begin recording, or F2 Display Data to display live data without recording.
You can also just press the 0 key to start logging.
3. Pressing Ok during data logging will toggle pause on/off, the same as using Ctrl+Spacebar in the PC based Scan Tool Software.
4. Use the up and down arrow keys to reveal more PIDs.
Use the Left and Right arrow keys to scroll up and down a page at a time.
(Hint: When held down for more than about a 1/2 second, the keys will "auto-repeat" just like a PC keyboard.)
5. Pressing F1..F4 and Ctrl+F1..Ctrl+F4 will insert the notes 1 thru 8 into the recorded data.
6. Pressing Enter will toggle between Metric and Custom units.
7. Pressing Ctrl+Enter will toggle between small and large text display.
8. Pressing Ctrl+DownArrow, will toggle “inverse screen” on/off. Inverting the screen can help visibility in direct sunlight.
Please check EFILive's FlashScan BB Logging Beta Forum for updates, hints, tips and tricks that are not described in this Readme_First.rtf file.
