Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: Serial V2 questions
  1. #31
    Aug 2007
    Thanks so much!!!
    So far so good.
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
  2. #32
    Aug 2007
    Quote Originally Posted by Slowrc View Post
    Thanks so much!!!
    So far so good.
    I am logging wideband serial 02 data now!!!!!!
    A big thanks to , Joecar, and Mrprick.
    Ps Your name does not suit you, You are a hell of a nice guy Mr.
  3. #33
    Nov 2006
    I
    It`s Irish.
    LC-1 WBO2
  4. #34
    Aug 2007
    WOoPs, wrong boot block, now I have...
    Bootblock version 2.06.02
    bootblock date oct 16 08
    firmware version 2.06.06
    firmware date dec 14 08
    I am pulling the EFI live out again after months of down time due to time and computer problems.
    Can someone refresh my memory on getting my bootblock and firmware to show up on my V2. The directions from this thread don't help since they are from an old version. The above versions are the ones I assume I still have in my V2.
    Thankks in advance!!!
  5. #35
    Nov 2006
    You can see the BB & FW in the Firmware tab of EFILive Explorer or
    press F4> F3> F1> scroll down on the V2 itself.
    LC-1 WBO2
  6. #36
    Aug 2007
    Thanks so much!!!
    Looks like I am on the latest bootblock 2 06 02 .
    Can I upgrade straight to the firmware to V2.06.012 from 2.06.06 or do I have to upgrade the ones in between one at a time until I get the latest. Just want to be sure I am doing this right!
  7. #37
    Yes, latest bootblock is 2.6.2.
    Latest firmware is 2.6.24.
    Yes, you can go straight from 2.6.6 to 2.6.12 or to 2.6.24.
    See here for latest 7.5.6.104/8.1.2.84 software: showthread.php?t=12834
  1. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 07:06 AM
  2. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 11:01 AM
  3. serial wideband autove questions
    By Slowrc in forum General
    Last Post: February 23rd, 2009, 03:01 AM
  4. fjo serial cable questions..please help
    By articSS in forum Black Box Logging
    Last Post: October 28th, 2008, 02:05 PM
  5. Where are we with serial WB???
    By Redline Motorsports in forum FlashScan V2
    Last Post: August 13th, 2008, 08:26 AM
