Results 1 to 8 of 8
Thread: Shift timming
    Aug 2008
    Default Shift timming
    Can anyone give me the name of someone who is good with allison trans. tunes. I want to change the shift timming at low throttle for a tighter shift but don't want to trash parts. Nobody seems SURE how to do it safely. Scared and looking to buy this tune
    2008 crew cab LTZ, turbo back 4", EFI and some other stuff
    Senior Member DmaxHawk's Avatar
    Apr 2008
    You might want to talk to Mike L. and see what he says. Mike is probably the best Allison guy in the US.
    07 El Bee Zee
    Little faster than stock...
    Aug 2008
    Where do I find Mike L.
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Mike will probably tell you not to adjust these parameters.
    I would recommend that if you want a firmer shift that you lower the desired shift time vs. TPS modifier table 25ms increments in the cells 0-50TPS and allow the trans a couple of days to learn in between your adjustments. I have my trans tuned to shift nice and firm at part throttle using this method.
    I would not advise remote tuning these parameters as the consequences could be ugly.
    Nick
    Aug 2008
    Sorry, Nick I am not that smart at this but what do you mean when you say remote tuning?
    Apr 2008
    Quote Originally Posted by bdr2008 View Post
    Mike's shop is 724-870-7300
    Quote Originally Posted by vortecfcar View Post
    Nick
    X2
    07 El Bee Zee
    Aug 2008
    Thank everyone I will let you know how I make out..
  1. 40 Degrees max timming, i want more
    By fezz57 in forum Gen III V8 Specific
    Last Post: November 5th, 2011, 07:36 PM
  2. cos 02020003 adding timming?
    By Boosted GMC in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 21st, 2008, 01:17 PM
  3. Question about Pilot timming for LBZ...
    By epb091786 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2008, 11:47 PM
  4. Duramax timming
    By Rambo in forum Duramax LB7
    Last Post: April 7th, 2007, 07:23 PM
  5. retard timming for N.O.S. help please
    By RandyWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2005, 05:52 AM
