thankx guys , and i do ,,
Success!!! (with build 81) Everything went smooth and the customer is very happy. P&R to the rescue again! You guys simply rock
8.7 @ 84 (1/8 mile) bolt-ons
Hello Folks, I am having a similar problem as stated above. First off I must say I only use EFI Live on my personal trucks so my experience with this nature of problem is limited. Next I bought a wrecked 2007 2500 Silverado and had the damage fixed (nothing with engine ecu's etc etc). The truck before I acquired it had the egr delete and turbo back exhaust installed. My assumption is someone has had a "plug and play" tuner to delete egr related issues, and that tuner was removed before the insurance company totaled the truck. My problems now are that I need to update the ecm for the egr delete but when I try to download either with 7.5 or 8 I get "Merge file: C:\Program Files (x86)\EFILive\V8\Merge\M~~.cmz not found" I hadnt used my software in about 6 months so I made sure all was up to date and updated firmware then software 7.5 then software 8 then firmware again then double checked that all were current in updates. What my next step? I'm sure it going to be something simple stupid that I'm overlooking.
Thank You
to add note to above
I downloaded transmission ecm with no issues and Im able to open tables etc..etc..
Which software build version are you running (go Help->About)...?
7.5
EFILive_Tune.exe V7.59 (Build 318)
8
Version: 8.2.4 Build 312
7.5
8
windows 7 ultimate operating system
windows 10 pro upgrade in near future
I pm'd Paul (the software developer).
Thank you
Is it possible that a previous tuner has ecm locked or coded so I can't download?? I was just curious being I can download and modify transmission. Tcm
