Results 1 to 10 of 19
Thread: E38 Pcm now dead
    Jul 2008
    Default E38 Pcm now dead
    Please help any assistance is greatly appreciated. I also apologise in advance for the length of this post.
    Ok tonight a mate came over and I flashed a tune into his E38. The cal was from another car which I had spent much time on configing. Both vehicles are LILPG powered Holdens with L98's, both 6l80E's. Both are 2006 models.
    Anyway I flash in the cal's (I must admit without removing the original cal first, brain snap and forehead slap for me I know) no problem. Drive 40km up the road stop for a short time after reading logs etc, no problems. Go to flash in another Cal and PCM packs it in. I again go to flash the cal in and get the following
    '21:28:20.968: Interface firmware version: 2.6.5
    21:28:20.984: Interface firmware model: FSV2
    21:28:21.000: Interface firmware version: 2.6.5
    21:28:21.015: Interface firmware date: Oct 28, 2008
    21:28:21.015: FlashScan serial number: 003689852244
    21:28:21.031: FlashScan license number: 003689852244
    21:28:21.046: Disconnecting ...
    21:28:21.703: CAN-VPW Bridge Deactived
    21:28:21.703: Disconnected
    21:28:22.359: Scanning for EFILive FlashScan V2 USB
    21:28:24.781: Scanning for EFILive FlashScan V2 HAPI
    21:28:24.968: Interface firmware version: 2.6.5
    21:28:24.968: CAN-VPW Bridge Actived
    21:28:25.000: Current protocol set to: "ISO 15765 CAN"
    21:28:27.046: Current protocol: "ISO 15765 CAN"
    21:28:27.062: Interface firmware model: FSV2
    21:28:27.078: Interface firmware version: 2.6.5
    21:28:27.093: Interface firmware date: Oct 28, 2008
    21:28:27.109: FlashScan serial number: 003689852244
    21:28:27.125: FlashScan license number: 003689852244
    21:28:29.203: Interface firmware version: 2.6.5
    21:28:31.250: Getting status...
    21:28:32.265: Status: Calibration missing.
    21:28:50.250: Bootloader version: E38a_v1.6C (0C56-F506)
    21:28:50.265: Preparing ECM for reflash...
    21:28:50.281: ECM reports "Not secured!"
    21:28:50.281: Initializing ECM...
    21:28:51.515: Initializing ECM, step 1 of 4
    21:28:51.515: Initializing ECM, step 2 of 4
    21:28:52.750: Initializing ECM, step 3 of 4
    21:28:55.203: Initializing ECM, step 4 of 4
    21:28:55.625: Initializing bootloader...
    21:28:55.906: Initializing bootloader, step 1 of 7
    21:28:56.250: Initializing bootloader, step 2 of 7
    21:28:56.593: Initializing bootloader, step 3 of 7
    21:28:56.937: Initializing bootloader, step 4 of 7
    21:28:57.281: Initializing bootloader, step 5 of 7
    21:28:57.625: Initializing bootloader, step 6 of 7
    21:28:57.968: Initializing bootloader, step 7 of 7
    21:28:58.968: ECM ready for reflashing.
    21:28:59.078: Request GM operating system...
    21:28:59.093: GM operating system: 12612381
    21:28:59.843: Request serial number...
    21:28:59.906: Serial number: 86K16169B4AX
    21:29:00.812: Erasing ECM flash memory... (please wait up to 120 seconds)
    21:29:05.062: Flash chip could not be programmed.
    21:29:05.296: Checksum of flash failed after write completed. Please reflash the controller.
    21:29:05.328: ECM is in an unknown state.
    21:29:07.437: Clear emisison related DTCs...
    21:29:09.500: Interface firmware version: 2.6.5
    21:29:10.531: Clear DTCs for all modules...
    21:29:12.578: Interface firmware version: 2.6.5
    21:29:13.843: Disconnecting ...
    21:29:14.484: CAN-VPW Bridge Deactived
    21:29:14.500: Disconnected
    21:29:14.500: Reflash failed.
    21:29:20.578: Done!'
    So basically it is telling me that there is no Cal in there and that I need to flash another one in. So I try again, still no luck, try again and again with no glory. So I contact a couple of well known Pro tuners and they both give me advice which I follow still no luck. I also attempted to read the tune in the PCM and there is absolutely no cals loaded at all, read came back empty. See attached.
    I also got this message,
    This version of the EFILive Tuning Tool has not been
    configured to display this PCM's operating system.
    This may occur if...
    your PCM has been updated by a GM dealer
    to fix a software problem in the PCM.
    OR
    you are attempting to load an EFILive custom PCM
    program without installing the matching *.cal file.
    OR
    you are attempting to load a non-EFILive custom PCM program.
    Please save this calibration's *.tun file
    and email a copy of it to: support@efilive.com
    so that we can add support for it.
    The car will not start etc.
    I have tried multiple times to flash in the cal, I have tried a full reflash, nothing seems to work. The car drove perfect from the initial flash but once I tried to flash in some changes that is when the problems occured. BTW there was no voltage changes, eg radio, windows etc used whilst flashing.
    Please help any advice is greatly appreciate, I have never had a problem like this before.
    BTW Thanks to Jezza and Steve from Oztrack, I appreciate the time and advice gents.
    ls1vt209, I forwarded this to Paul and Ross.
    Please send in the *.blx file as per this web page:
    http://www.efilive.com/index.php?opt...111&Itemid=121
    Once I have that file, I can see exactly why the PCM is rejecting the reflash. It may be a real failure, it may just be a software fault.
    Some things to try if you have not already:
    1. Disconnect battery for 30 seconds, reconnect and retry the reflash.
    2. Make sure you have the latest EFILive software installed and that you have run EFILive's "Check for new updates" start menu option.
    Jul 2008
    Paul, I have forwarded all blx files from last night as requested
    Thank you for the suggestions, we did disconnect the battery and I have the latest software.
    Cheers
    Nigel
    Nigel,
    It is certainly a strange fault, once Paul looks at the .blx file he can confirm exactly what the error is, but to me it looks like a software error rather than the ECM, from the time the erase command is issued to the software failing on the reflash it was only 5 seconds. Though it might be an erase issue with the flash memory, we'll wait and see, I'm only guessing.
    Jul 2008
    Yes Ross it looks strange, everytime it tried to erase the existing cal it stated there was nothing which I thought, well no problem, it will just right to it.
    But that is where it got interesting when it would not right at all.
    I have forwarded some blx files and there will be some more once I get them out of a mates laptop, we tried 2 in case it was a pc issue.
    Quote Originally Posted by ls1vt209 View Post
    Cheers
    Nigel
    I don't have them yet, did you send them to paul@efilive.com?
    Jul 2008
    I have sent them to there now. I initially sent them to support.
    Cheers.
    PS The car is now at the dealership.
    The blx file shows that the PCM returned an error saying that the flash could not be erased. Right now the only thing that we know of that could cause that is if the flash chip in the ECM is faulty. It may be heat related which could cause it to fail only while the ECM is hot. It may be worth trying to reflash after it has cooled overnight.
    If the dealer can't recover the ECM, and if you've still got it, please send it to EFILive in Melbourne for analysis. We'll send you a changeover ECM.
    P.S.
    You're running a very old version of the EFILive software (V7.5.4.66).
    I recommend upgrading to the latest version V7.5.5.72 from our web site here: http://www.efilive.com/index.php?opt...=48&Itemid=124
    Then after it is installed, run the start menu option: Start->All Programs->EFILive->V7.5->Tools->Check for New Updates which will update it to 7.5.5.81
    Jul 2008
    I actually used two different laptops to try and flash into the ecm. The second one has 7.5.5 build 78.
    My fault for not updating, I had to borrow a laptop and did not check the version of EFILive due to children destroying my one with beer.
    I have since updated all PC/laptops with the latest versions.
    I will get back to you in relation to what happens with the PCM as the car is at Holden and I guess getting it back if it is fixed under warranty is pretty limited.
    Cheers
    Nigel
  1. Dead 02
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 09:29 AM
  2. [B]HELP[\B] Another Dead PCM
    By ls1vt209 in forum Gen III V8 Specific
    Last Post: March 26th, 2009, 04:13 AM
  3. Is my PCM dead?
    By kenkaru in forum Gen III V8 Specific
    Last Post: March 22nd, 2007, 08:08 AM
