The PCM has been replaced under warranty and Holden have put it down to a possible power spike from an unknown location. Sorry guys cannot send the PCM down to you all for analysis as Holden will not part with it.
I would just like to say a big thank you to all that had an input into this thread and also people I spoke to over the phone about this problem,
Blacky
GMPX
Joecar
Steve Bennett from Oztrack
JezzaB
Given that it was not an EFILive issue I could not see a reason why they would not.
Cheers
i've had a similar issue with the trans controller in my auto.
load a tune into. go for a drive logging. go to update flash again. eflive reports its a different serial blah blah even after multiple tries. turn car compeltly off for a bit, turn to acc and try and again and it still wont work. drive home. give it another go and it takes the cal.
even had it take a tune multiple times and then when car is started get the dreaded tcs-off = problem. turn car off, turn to acc. reflash and then all good.
If you flashed the ECM with an old installation, i wonder if that may have caused the issue?
The traces that EFILive was logging showed the ECM was saying the flash chip had a problem (couldn't erase it), that is pretty much beyond our control. I'd say that Holden probably tried to put a tune in with the TechII and had a similar issue, hence they replaced the ECM. This is the first time I have ever seen a flash chip literally fail!
