Here are two of my first logs. As I explained in other corners of this forum I have a 1997 Tahoe with a 2007 5.3 LMG, 4L60E, E38/T42 combination.
Beside some other problems the fuel economy or lets say the nonexistent fuel economy is a thing I have to work on.
As my knowledge of tuning is still in a steep learning curve I may need some help to interpret what I recorded on the testdrives...
I took the opportunity to take my tahoe on a longer trip. I had to drive to the south of Germany. It was about 200mls, a forth of it through some small towns and country roads, the rest a longer stretch of our autobahn. I set the cruise to 70mls/h and watched the AFM working. It only kicked in when the road went downward (very little was enough to get V4 mode) .As soon as the road was flat I was back to V8 mode. Without the cruise it felt that the slightest movement of the throttle and I was back in V8 mode. I think there is room for some refinements so that the V4 mode is kept longer even with a little throttle applied.
The overall fuel consumption was 13,7mpg which is what I think very high for that very careful right foot.
what could be done to get better milage out of a e38 controlled LMG 5.3?
Is there a way to get a kind of lean cruise mode? Could I tweak the calibration to get more miles out of a gallon? Ideas to widen the V4 zone where adequate..?
To the logging of the important PID's. What should I keep an eye on when I am looking for a better mileage?? Could there be something wrong in my application ?? The only thing I see is a strange TCclutch slippage, like a sine wave (30 - 80rpm)
The fuel consumption Patrick and Vegasrobbi report are a whole different story.
best regards and thanks for your help
Harald
