ok, I advanced the high octan spark table by +5deg (Spark_1)throughout the table and set B5157 to 0. I also added the octan scaler to my PID list.
First run was with the +5deg setting
Second run another +3 degree (Spark_2) added to the high octan table. (total +8deg)
I have to admit that the second run had a little more load on the engine, I had to drive up a longer hill.
The summary is about 3deg KR and about 6 deg KR in the two runs.
I watched the KR map but I am still not able to interpret that cell counts. Is each count a knock retard? knock retard by xx deg?
The octan scaler was 0 . That means I was running the values of the high octan table all the time.
How should I proceed? reduce spark advance in certain cells..?
Harald
